Hi.
just removed the valve body. I took the filter off and there was a round ball under the spring. Not like the ones I saw on you tube. I split opened body and found just 1 ball in the top half.
First question. Will the ball under the spring held in by the filer work?
Second. How many balls should they be in the valve body?
It has been shifting fine for a long time. It had just started to slip shifting into 3 rd gear
