The bottom of the lock nut has a built in seal ring. Buy a new nut or back off the nut and clean the stud, adjust the band, then wrap close to the case tightly with several layers of teflon tape. then hold the stud and tighten the lock nut. the nut will compress the tape into the threads and case and seal the leak. Easier to just replace the nut.
