C4 Deep Pan
BroncoDon
Laguna Hills, CA
My C4 Trans has always leaked even after replacing the gasket. I was thinking my next step is to replace the pan. It was suggested by a friend to use a mustang deep pan. Is there any better suggestions ? I know WH sells a Art Carr pan but I would like some more input.
Thanks,
bronconate68
Vancouver, WA
I have ran a C4 for about 700 miles now. I rebuilt it myself with the B&M kit and used the B&M deep pan. At this time I do not have any leaks. I had a leak at the dip stick, I had to modify the DS hole on the pan for a Lokar DS. I ended up using JB weld and it worked. Now if you are leaking from the pan gasket, if it were me I would us good gasket maker and the gasket to seal it up. If that doesn't work you may need to mill the bottom of your transmission to level the surface the pan seals against. I don't know any reason why that surface would warp.
The only real truth I know is that my transmission is not leaking.
If I'm way off and there is a much better way I sure would like to know it.
broncow72
Village Idiot
Spring,TX.
Thanks,
I've been chasing a leak in my C-4 for 2 years now and finally found it.... Dipstick tube. Check this first before you go spending money on a deep pan, which by the way requires a different filter with a lower pickup.
Bronchole
Chatsworth, Ca (LA)
The B&M pan comes with its own filter and extension. But it is a B&M specific filter.
You could still use any variety of the stock C4 filter with the B&M deep pan but they wouldn't pickup at the bottom of the pan.
B
BroncoDon
Laguna Hills, CA
I can see it leaking out of the seal, which by the way was just replaced after the tranny was rebuilt 500 miles ago. At the time of the rebuild the pan was severely banged up and dented so we tried to make it correct but obviously that didn't work out. It is a "Step Pan" and I haven't found any of them on any of the vendors sites.
pinenuts
Hereford, AZ
I too had a leaky C4. It was due to the flange on the stock pan being slightly distorted. Rather than trying to straighten it, I installed the B&M pan. Now I have no leaks and a little extras capacity in the pan.
67ster
The stock factory pan is usually ruined from overtightening the bolts . The guy we used to have build our C-6s , was an ex B&M tech. and he swore by using the heavy ribbed cast aluminum deep pan. He said the aluminum pan was stiffer and acted as a "girdle" plus the extra oil capacity helped because the biggest enemy of any AT is heat.
