in process of 3 year frame off resto, I have a C4 transmission assembled from a busted C4 that came with truck, and "working when removed" 2wd pan fill from van or pickup. finally at point where truck is assembled enough to test tranny and it will not shift into 3rd gear. Engages in reversed fine. When in D, engages 1st, does not up shift, coasts when let off gas. 2 position will start in 1st gear and upshift to 2nd, 1 engages 1sst gear.
I have scoured the internet trying to find solution, to cut down on some common Q's, issues, here is what I know.
-transmission fluid level is where it needs to be
-linkage is fine, valve body is seated where needs to be, as is kick down lever.
-kickdown (cable on my build) is fine , not hung up,
-all new seals, clutches, steels, thrust bearings, endplay in spec
-pin is in modulator, modulator is seated fine, modulator opens completely at around 20inHg,
-manifold vacuum is low at 12inHg, measured at hose where it attaches to modulator (still need to tune holley carb)
-putting shorter pin in modulator to account for missing vacuum (8inHg) does not change shifting issue
-switching valve body to a another "sold to me as working VB" results in the same issues
-clutches, servos, bands all engage as they should when air tested.
-governor does not flutter when air tested
-the governor in there now is from a "working when removed" tranny, I did not go through it though. Rest of tranny looked fine, just old fluid, nothing in there led me to believe it had any issues.
I'm 3 years and ~$30K in. just want to drive this thing. Please, any help is appreciate. I'm at the point that next step is to send it to a local rebuilder.
