C4 linkage adjustment
ryan_289
Russellville, AR
The 76 Bronco I just purchased I think needs adjustment to the shifter linkage on the C4 automatic. It wont always go into park. It acts like it needs a litte more sometimes. That should just be an adjustment shouldnt it?
scsm76
Shaver Lake, CA
At the bottom of the linkage at the tranny there should be an adjustment. If it has a body lift the linkage may requires some mods to allow it to adjust far enough. Don't wait to adjust this, and until you do don't let it idle in park unless you are sitting in it. Several people including myself have had problems with them rattleing in to reverse and then you have a run away bronco.
NoJoe
san jacinto,ca.
Many years ago I rebuilt a Olds hydramatic and when filling it with old type A atf from the front of this monster it jumped in gear and ALMOST pinned me in the garage, I was much Faster then, old hydros had NO park until you shut the engine off and put it in REVERSE which was then PARK sorta, Joe.;D
