c4 metal trans lines with hedman headers
jonlorio
I swapped my 3 spd to a c4 during the build. I have never seen how the stock c4 metal lines are ran since I had a manual before the tear down. I have the 'in-line tube' pre-bent hard lines for the c4. I am running hedman long tubes also. I only spent about 10 min under the truck trying to thread the lines in, but it appears next to impossible. I have searched but did not come up with many pictures or explanations other than "try to get the lines to the top of the frame rail". Do I need to modify some of the bends on the pre-bent hard lines? Pictures are worth a thousand words some times.
major
Knoxville
lines
If you got the pre-bent lines from bronco graveyard %):mad:
I had to rebend almost every angle on them. I am running ceramic coated Duff headers and I had a hard time getting the lines to fit not to mention getting enough of a gap so the headers were not touching the SS lines. Good luck and I hope this helped
