Took the bronco out 4 wheeling on Sat. and about 5 mi into a trail I noticed ATF leaking out of the bellhousing. I only had one extra quart which bearly got me back to the highway before the fluid got too low for the tranny to work. To cut a long story, I got more fluid, refilled the tranny and drove it home (50mi) with no problems. The next day I drove it down to the car wash to clean it up since I figured I'd have to pull the tranny to replace a seal. Anyway, the oil leak had stopped, so now I'm not sure if I need to pull the tranny or not? Is it possible that the transmission got too hot causing it to start leaking? The fluid did smell burnt, so I'm definately going to change the fluid and replace the filter. Any other suggestions? Thanks.
The C4 has a large B&M cooler, about 20k miles on it and about an 1800 stall B&M converter.
