C4 question
1966halfcab
Newbie
I have a 1976 pan fill c4 trans. With a 10.5 bolt pattern converter my question is can I use a converter with the larger bolt pattern in its place I am running a 1996 explorer 5.0
garberz
Bronco Influencer
Conejo Valley, Ca.
Yes. The correct 11 1/4” bolt circle converter will interchange. You can use the 96’ Explorer flex plate too, if you have it.
Mark
1966halfcab
1966halfcab
Newbie
Thanks for the quick response I am using the explorer flex plate just wanted to make sure the 11 1/4 inch torque converter would fit into my trans .
sanndmann3
Is there an imbalance issue that needs to be considered? original motor is 28 oz-in and the Explorer 50?
Jebus
Longview, WA
Only from the flex plate forward. The torque converter is balanced.
He would already be running the 50 oz imbalance harmonic balancer and flex plate with the stock 5.0
1966halfcab
1966halfcab
Newbie
That's correct I am running the original explorer flex plate and balancer behind that the old C4 transmission
BwoncoHowie
C-4 Wizard
It's actually an AOD/AODE flexplate that goes with the engine with the 50-oz weight, but it is compatible with lg. bolt circle c-4 torque converter.
Don't throw your 1996 engine out of balance with the early flywheel/flexplate
