Got s leak on the passenger side of the trans. I’m going to clean everything up then run it to see where it’s at. Could be the cooler line, but if it’s the servo, can I do this in the Bronco? No body lift.
If it's a leaking servo cover you may be able to replace the gasket with the trans in place. You'll need 3 or 4 inches of space from the servo cover because the servo and spring will surely come out when the cover is removed. You will also need to remove the valve body to get the band struts back in place after the servo is reinstalled. Not a fun job but better than pulling the transmission.
