Z Bronco
- Mar 17, 2007
- 1,139
My Bronco will shift the same with or without the vacuum hose hooked up to the vacuum modulator. No idle issues with the hose disconnected. It also is shifting early now from 1st to 2nd gear, and the firm shifts aren't happening, it feels stock now (shift kit in transmission). All this happened after a shop worked on my Bronco, I will not be going back to them. The Bronco is drivable, just different. Any ideas would be greatly appreciated. Thanks in advance.
My Bronco's C4 mods, all worked great before:
-A1 transmission lower gear set. 2.92 first gear (18% reduction) and a 15% reduction in 2nd gear.
-Lower than stock stall speed torque converter
-Shift kit
-BCB cable kick down (EFI conversion).
-Shift kit
