So my 74 is going to have a 2000 explorer 302. I already have the motor awaiting it's rebuild over the winter. I had the ecu programmed by efi guy and I'm doing the harness. I am picking up an np205 off a late 70's f150 or 250 that had a c6. I'm getting the mr5d out of a 94 f150 with a 302 and it's coming with the flywheel and clutch. Plus the pedal assembly and clutch resevour I know I will need some driveshaft work when it's all together and installed
My questions are on the pedals and little gotchas. Is the flywheel from a 94 302 going to work with the 00 302? And what's the deal with the pedals am I better off running the auto c4 brake and gas pedal? And adding a clutch. It kinda looks like the factory setup shoots over the steering column and has room to just add a pedal. But is it worth it since I need to also hook up the efi throttle cable and I will be adding power brakes at some point before completion.
Also I removed tge steering column to sell with the c4 but should I be keeping the steering shaft? Or is that also different. I don't know if a knew column comes with it or do I just save the end that connect to the power steering box. I don't want to get screwed I. The spring when I start to reassemble everything
Other then that is there a company that sells prefab cross members for the tranny and np205?
I have a 2" body lift and 3.5" suspension lift so I think everything will fit.
