c4 tranny chirping
Mitchm25
Monmouth County NJ
Fellas, after a 5 year stint with a FJ40 I'm back where I belong in a EB. I'm so excited. The fj was fun but its no bronco.
So here is my first issue, when the truck is in gear there is a loud chirping noise, the second it goes into park or is at cruising speed it goes away. Its sitting on 35s, all suspension lift. Also not sure if it helps but it has a wratchet shifter.
Sounds like Tweety bird is getting beat up in my tranny.
Justafordguy
Welcome back.
Sounds like you could have a cracked flex plate. Also check and make sure the converter bolts are tight.
Mitchm25
Mitchm25
Monmouth County NJ
thanks for the flex plate idea, the more I read about a cracked flex plate the more the symptoms point in that direction. From what I can see there are no cracks. Is there a way to confirm that is the issue without pulling the tranny ?
Justafordguy
Unfortunatly there really isn't any good way to see up in there without pulling it. You may try to unbolt the converter and see if you can get a mirror/light in there. Removing the starter will also get you a little access. Usually they crack right where the crank bolts are and you really can't see that part without pulling it out.:(
Justafordguy
If it's the flex plate it probably won't hurt anything but it will eventually tear the center out and you will be stuck on the side of the road.;)
