75Denver
- Jun 5, 2007
- 573
This is a two part question.
1. I've been reading through many of the past archives on this topic and it sounds like everyone has thier own methods of removing and installing. I've taken out the exhaust, starter, and drivelines. Last night we were going to remove the t-case but couldn't get to the top two bolts between the tc & adapter. Not to mention the crossmember bushing bolt closest to the shifter (impossible to get to even through the tunnel hole). We ended up just cutting the nut off the bolt and removing the entire crossmember from the frame. The problem now is should I just remove the t-case and tranny at the same time? I know it'll be heavy as S but I'll have a tranny jack from HF. Or, does anyone have any suggestions for removing the top two t-case bolts? I know, it seems like it should be easy. I didn't think my hands were that big.
2. This is more of a concern than anything at this point. I was reading the Chilton and Haynes manuals and they recommended wrapping the tranny ends with bags to avoid getting dirt inside. The trans I bought was a rebuilt 77 Bronco c4 but has been sitting without proper cover. When I bought it, I put a bag over it and have it inside my garage. Will there be any future ramifications of it not being covered before I got it? It looks really clean but I know it doesn't take much to clog the valve body, etc. What are your guys' thoughts?
Oh, and does it matter putting a 77 c4 into a 75 Bronco? I know the 77 internals have heavier duty bands but is there going to be an issue with the torque converter and flexplate?
