im back in the garage with another issue and im thinking i am just overlooking something simple. Ok here it is.
after getting my c4 back from the local transmission shop and re-installing i can not get D gear to respond as all 3 speeds.
I have filled it to correct amount of fluid and check to make sure i was getting vac to modulator.
When i go to drive it goes into reverse perfect and then when i shift in to drive it only responds in first gear and does not continue to second or 3rd. However when i shift from “D” to “2” it goes into second quite easy. But still no 3rd gear.
