DonH
I bought a C4 and T-case from a 1977 Bronco. They are sitting together on my garage floor with the cross member. The T-case has twin stick shifters. I assume the twin sticks go through the same hole as the T-shifter did. I am going with the Winters floor shifter for the C4. There wasn't much instructions on where to place the floor shifter. The brackets for the C4 are made for a two wheel drive car. The cable does not have room between the the twin handles and the T-case. I will have to make a bracket to the out side of the levers. I thought about making something fastened to the crossmember but if the engine rocks back and forth the shifting link may cause problems. I will have to build somthing of the C4. I was wondering if others may have done this. Does the Shifter mount on a console? I don't have the seats installed and maybe do not have the seats. The 67 seats are not good. Does anyone have pictures of the shifter installed?
