C4 vaccum line
mattyq17
Where should the vacuum line go from a C4 transmission? Right now it is going to the back of the manifold but I read that it should go to one of the ports on the front of the carb. I have an edelbrock 1406 carb, with the front left port going to the distributor and the right one is currently blocked off. Thank you.
Rustytruck
It goes to manifold vacuum. One of the ports on the carb also has manifold vacuum so it works either way if you get the right port. There is a vacuum port on the carb that has no vacuum signal at idle that is for the distributor advance.
76YETI
KC METRO
The elderbrock 1406 has a stand alone vacuum port for power brakes on the back of the carb in the middle that is blocked off with a plug. Remove the plug, add the Edelbrock Adapter fitting 8080 and your in business.
mattyq17
mattyq17
Thanks guys I will leave it at the back of the manifold as it looks cleaner than running another line to the front of the carb.
