cable shift
vap13
I know in a past post someone was was going to try a cable shift for the AOD for the stock column shifter. Anyone know if this worked? Having trouble trying to get the hard linkage to work right.
Colo77Bronco
Colorado Springs
Do a search on "AOD conversion" and there is a post on the first page of results with pics of a perfect hard linkage set-up. I copied it and it is easy and works perfectly with everything ligning up correctly on the indicator.
V
vap13
I will do the search and check out the post for the linkage. On the ididit cable shift I was concerned that there was not enough room for the bracket on the steering column.
