Chucks steps for adjusting:
I find that this is very hard to explain without hand motions but I will try.
With the spring removed push the lever foreword, if it will move more than 1/4" the brakes need to be adjusted.
1 push lever foreword and remove
2 put lever back on as close to the back stop as possible and tighten nut
3 push lever foreword, if it will move more than 1/4" repeat 2
4 if you can not get less than 1/4" of movement remove the lever, reinstall it below the back stop and tighten nut.
5 note where lever is
6 turn lever backwards some then forewords, if it stops in the same place turn lever backwards more and check again.
7 repeat 2 and 3 above. if you still have more than 1/4" repeat 4 5 and 6 above.
8 when you have it right (less than 1/4") adjust the E-brake so that the lever is just off the the back stop.
9 call me if you have problems @ 888 304-2945
