CAGE style Dana 60 radius arm mount drawings???
broncosbybart
I have a set of Duff's extended arms that I'd like to bolt directly to a D60 front axle. I'd like to fab up some of the old CAGE style mounts. Anyone copy them and care to share dimensions or drawings???
allenfahey
I have Cage arms and can cut out some cardboard templates for you. I'm pretty sure the bolt locations will be different between the Cage and Duffs arms even though Jim designed both types of arms. If you need the templates PM your mailing address.
broncosbybart
broncosbybart
thanks for the pic and message. sending you a PM. looks like the brackets have holes for the coil cups to mount directly to them? interesting. do the brackets use some sort of bushing in them for the radius arm bolts? if so, i'd have to figure something out for those.
sstclair
The Cage brackets are a direct bolt up to Duff arms.. that's what I have on my 60. They do take the same bushings on the bolts. Also, Sexton Offroad had them in stock when I needed mine.
-Steve
KyleQ
I would say to ditch the idea of fighting to get to the coil cup bolts inside that arm bracket and simply add angle iron to get a better coil angle and easier mounting location.
The larger flat surface keeps the coil cups from moving at all...
