If you are running wide open throttle on the dunes and street, a cam that gives a lot of duration will give you the roughest idle for the "bitchin" factor. It also helps out if you have not had your heads done. A high lift cam needs good breathing heads and headers to maximize your investment. The older cams with longer duration don't have the lift but keep the valves open longer to help the engine breathe. The downside is you will have crap for vacuum so vacuum assist brakes, a/c and such will be virtually useless, but it will lope like a striped eared gorilla and make power above 3000 rpm! If you run an auto, you will need to get a stall converter that matches the cam and rpm required to keep it running while stopped (the idle will be higher and with a C4 it will want to drive off with a stock stall) and allow you to launch from the line. If you are changing gears, you may want to go a little taller than 4:10 as with 35's, they will be equivalent to a 3:50 stock gear ratio. You may want to step up to the next taller gear while you are in there so you can hook it up and make it howl.
