stock74
- Mar 14, 2004
- 242
The after market heads will flow very well. As far as factory ford heads go, the best flowing heads I know of are gt-40 heads. The next step down in factory heads, someone correct me if I am wrong are E7TE heads. Do you know what the compression ratio of your engine is? If it is a low compression motor then you will either want to stick with a smaller head or some how raise the compression ratio. Again, if I am not mistaken you will sacrifice some engine compression by putting bigger heads on and in the case of an engine with an existing low compression ratio loosing more compression is going to be counter productive when trying to make more power.
