- Nov 11, 2007
- 8,235
Hi, I was poking around the comp cams Camquest camshaft software and noted an interesting point: Vehicle weight has a larger effect on camshaft selection than I had fully considered, and I'm willing to bet most who select camshafts don't think a lot about this issue either.
Here are some findings using a 5.0 roller, x303 heads, 1.9/1.6 valves, 9.0 compression, carb, headers, default selection #2 for truck with improved economy and torque (selection 1 resulted in no camshafts available):
The default weight comes up as 2500# (a very light mustang), this is a problem as I bet most folks don't change this setting or truly realize what their truck weighs empty or loaded.
At 2500#'s, the software recommends 20 camshafts, starting with XE258HR (1300-5300rpm range) and going as high as a 281HR (2000-6000rpm).
If I change the default weight to 4000#, which is much closer to our one or two person operating weight (my GVW is 4900#) the software only has 6 camshafts, starting with 258HR going to 266HR, I say 6, there really is only 5, because one is a NOS camshaft, and two repeat depending on if your motor was originally a roller motor or modifed to roller.
Now, what if we use our GVW? 5000#'s gives only two camshafts, the 260HR, and XE258HR. One is a carb only and one is an EFI camshaft. Powerband is 1200-4500/5000.
Interesting to find that only one camshaft was recommended in each weight category, the 260HR part number 35-410-8.
