Anything can fit with enough modification. Since your question is about as cryptic as it gets, I'm leaning towards NO.
How about a bit more specifics about what size radiator, how you're going to mount it, what kind of fan you're going to use and your fabrication skills. That might better help others answer your question.
Griffin Aluminum Radiator
Part # 7-266BV-BAX
core size: 19.00x20.88x2.22
inlet/outlet: driver top - pass bottom
Fan
15.50
part # TA16A1004
DCM-Tex Straight blade pull
I have no fabrication skills to write home about
This description is about as good as it gets, there, did my best to be not so cryptic Parts are in FL so I cant go out and measure. I'm gonna try to mount it in the stock position as best it can go, if it can go.
I have a 66 with a 302 standard belt system, i have a 4core radiator and a black magic cooling fan. In order to make it fit i had to modify/ remove the core support to get proper clearance between the fan and the water pump pulley.
It did take some fabrication but that's half the fun.
