aaronmichorn
Having trouble sealing up a new rear gas tank. Third try and the tank still leaks. New plastic tank, new sending unit, new seal, new lock ring. I drained the gas out of the sending unit hole today down just below the level of the hole. I jacked up the backend to get a little more out of it. The fuel level was about 1/2" below the hole. I dried it off, and started reinstalling with RTV when I notice fuel was still slowly leaking out. I pulled everything back out and dried it off again, and lit a match to see what I was doing ( actually a flashlight). there was fuel coming out of one of those gimpy retaining clip bolt holes. I thought maybe there was a crack inside of the tank backing up to the threads for the bolts.
So, I drained the entire tank, and removed it from my truck. I filled it with water up to the lip of the hole, and no water was leaking at the bolt hole anymore. Any ideas?
