ProjectBronco70
I have a 302 with a 2bbl Motocraft carb, electric choke etc. It starts up fine and runs well for a little while but when it gets warm, if I slow down or stop it dies out. The only way I can get it started is to put the pedal all the way to the floor and sometimes that does not work. If I let it sit for a little bit, I can start it back. It reaks of gas almost like it is flooded or something. Sometimes you can see moisture around the base of the carberator which I assume is gas. I inspected the float and sprayed carb cleaner all around and removed the fuel filter and sprayed it out. I have a plastic gas tank so I don't think it could be trash. Any ideas? Thanks for the advice in advance.
