- Jul 31, 2001
- 9,048
Caster desired on D60...what is stock? Knuckles are off so I can "dial in"...
OK, '78 F350 D60 is going in up front. Drivers side is being shortened and PS is being cut also...
I've got 40" tires, do I want more caster than stock with the pinion straight at the t-case or do I want to stick with the appr 5 deg stock setting?
How does a larger tire affect caster setting? I drive this a LOT on the highway and did Moab 3 x last year just so you know what my goals are...thanks
