Bronco Boomer
- Nov 19, 2013
- 4
Dear Bronco Yoda(s),
Let me begin by saying I am doing a body off build and it is my first Bronco. There, the stage is set for the appropriate ridicule!
I have been reading lots of threads with regard to wheel offset and backspacing, but would like to revisit the topic to achieve better definition of the cause and effects of adding more backspace.
Scenario: ’75 Bronco with ’76 disc brake setup. 3.5” suspension lift and 2” body lift and a Heim Joint steering setup. This Bronco will be a daily driver with the occasional off-road weekend. There will not be any extreme off-roading or rock climbing.
I have found a few types of rims that I would like to install, but they all come with a 4.5 to 5.5” backspace. They are all 17” rims with either 8 or 9” width. I plan on going with a 33” x 10-10.5” wide tire, but if all fits well I may go with a larger tire later.
If I understand the threads correctly, I will have no issues with the brakes or steering linkages and that the interference issue will be with the radius arm. I also understand that I can adjust the steering to prevent that interference, but will lose some steering.
So Yoda, the questions of the day are: How much adjustment is required for this scenario? AND what will the effects be on the steering?
Thanks in advance for mentoring a green Bronco Jedi!
