CB antenna question
muskrat
Good morning all.
I got my CB antenna installed over the weekend, and tuned to the CB radio.
The antenna was getting beat to hell by the garage door, so I decided to spin it off and spin it back on when needed.
Since I have removed it, does it need to be re-tuned again when I reinstall it?
Thanks folks.
Dave
JAFO
Beaverdam
I doubt it will make a lot of difference, but I am no expert. Tuning is adjusting the length. I'd expect it screws down to the same height. An SWR meter used to be fairly inexpensive. I have one I bought many years ago at Radio Shack. Tuning is just sticking the SWR meter in line and then seeing what reading you get. Changing the antenna height to obtain the best signal you can get. Lowest SWR value. 1.5 or lower. I think if at 1.5 that is good. Anything below 1.5 is better.
lonesouth
should be good to go. You could look into adapting a VHF antenna mount to you CB antenna to allow you to raise and lower it as needed.
Dlish
Sounds like your real problem isn't the cb antenna, but rather the height of the garage.
This is the perfect opportunity to: A. raise the garage roof and install a lift, heat/ac, etc. or B. build a pole barn for the Bronco, with a lift, heat/ac, etc.
A or B are really the only acceptable means to solve this problem.
JohnJohn
Richmond
muskrat
muskrat
Thanks for the help guys.
Oh to have a bigger, taller garage. Maybe in my next life. A pool sits where I envisioned my detached garage.
jw0747
San Antonio, TX
I take my antenna off when not on the trail and install it when going out. It was tuned only once. When I hit the trail I usually call the guys on the International Space Station and they confirm that it's working fine.
