centech wiper wiring ?
matt77
Southaven, Ms
Can anyone tell me what colors from the centech harness they hooked to the factory electric wipers?I can't get mine to stop in the correct position.
eb66to77
Bronc'Ownly
NOVA
The directions in the kit have an illustration of which wires you need and what you need to modify in the motor to hook it up. I wired in the delay switch and used only the power wire from the centech kit to run it. I used a stock delay switch and box from a '79 F-150
SC74
I only hooked up the fast and slow wires. I used a hot wire on each of the wiper motor wires to see what was what first. My "Park" wire did not work, so I just have slow/fast.
302fix
Mine have never parked correctly. I have to manually park them.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
There are a couple of articles in the tech section about getting the wipers hooked up correctly with the Centech.
brewdude
Groveland, CA
Check the tech section Lars did an article about how to add an intermitant wiper switch. I picked one up at pick-n-pull for $8. Real easy upgrade.
M
matt77
Southaven, Ms
I cant get mine to stop in the correct position.They stop up and down instead of side to side like they should.I looked threw the tech and everybody was going to intermentant wiper switch.I use the one centech gave me and everything is good other than the stop position.I was hoping someone could tell me exactly what colors to hookup on each harness.I've tried adding grounds and the other suj. that people have done and no luck.
moabbronco
Payson, Utah
I just used the stock harness for my wipers. They workde great so there was no sense messing with it. I still have the centec wiper harness if anyone needs it. I think I got a scematic from Wild horses tech.
Brewbro21
You don't have to modify anything in the wiper moter any more. Centech went back in and fixed that problem so they hook right up. I'll check my harness tomarrow if you still need to know how to hook them up.
Bronchole
Chatsworth, Ca (LA)
If what you are saying is that the wipers park in the down position then your problem is not in the wiring harness or switch. It's in the nut between the wrench and the floor!!! The arm mounted to the wiper motor needs to be removed and rotated 180°.
