Centech wiper wiring question
Nightstick
Bronco guy
I found the addendum for removing the ground clip, but I just want to make sure I'm removing everything I need to. In the pic, is the thing beside the switch the only piece I need to remove, or do I remove the other copper looking piece as well?
Also... How in the hell am I suppose to get this thing back together with the springy things going around the shaft!? Any tips are appreciated.
Nightstick
Nightstick
Bronco guy
Well I removed the other copper looking piece (the one that goes left to right in the picture), because it's only purpose is to be used with the other piece I had already removed. I had to remove the other two screws holding that plate down to get to the nut that held down the ground thing originally. Did so, tightened it back up and reinstalled the plate.
The tricky part was figuring out how to get the shaft back in with the springy things always wanting to come out. I ended up putting them back in their respective holes, depressing them, and putting a piece of solder in the top hole to keep the spring depressed while I slid the shaft back onto place. A few manipulations of the springy things as it slides down and it's good to go. Took only a few seconds.
blazinchuck
curious why you even had to go into the wiper motor for the centech?
ive installed this wiring harness in a 74 and a 77. i chose to reuse the factory switch...so that took some different wiring at the switch to work...but it works great
Nightstick
Nightstick
Bronco guy
Hmm. There is an addendum to the centech instructions. Viperwolf posted it a while back, so that's what I went off. Apparently there's issues with fuses blowing. I guess if you reuse the factory switch you don't have to do the mod, but I went with the centech switch.
blazinchuck
ok...so thats only if you use centech's supplied wiper switch? i didnt use theirs...it didnt have park,didnt really fit the dash, and not a simple upgrade for doing ford wiper delay switch.
good luck on your tho...thanks for posting, dont think ive seen that at all
Nightstick
Nightstick
Bronco guy
My intent was to reuse the factory wiring through the windshield and just wire the centech into it. I tried it and immediately blew a fuse. It's been a while since we did the initial install of the harness, and to be honest I don't remember what I did, but I don't remember messing with the wiper switch, so I'm assuming I just used the one with the harness. Blowing the fuse only makes me think that more. I painted the motor and installed a weatherpack on the harness side of the wires yesterday, I'll wire the motor side today and see if it works.
Nightstick
Nightstick
Bronco guy
The verdict at this point is that the low speed works, but no high speed, int, or park... Hopefully I'll get it figured out tomorrow.
z70what
Johnson City
Chuck,
What did you do to the stock switch wiring to make it work? I'm in the middle of rewiring with a centech harness right now have already installed the dash and centech switch. I'm curious what needs to be done if hte stock switch is reused..
Just wondering if i should keep the centech swithc and mess with the wiper motor or go back to the stock switch and modify the wires (as you did).
Luke
blazinchuck
i did that like 7yrs ago...centech was no help when it came to using a stock wiper sw with their harness. i might be able to check the color wire when i get home...i cant keep outside at work to check now(plus its pouring)
if it were me...id use the stock switch. the centech dont have park if i remember...plus if ya have the stock harness plug for the switch installed to the centech harness, then upgrading to wiper delay switch from ford is that much easier.
