Centeck and Ignition switch install WOW HELP
mrtnfischer
installing a new harness, no problem until I tried to put the Ign Switch back , did I lose some thing to hold the switch tight against the dash metal..see pictures
rydog1130
No pics are showing up...are you using their ignition switch or your factory switch? You'll need an adapter if your using your factory switch, that lawn mower style one with the kit is FUGLY...
WILDHORSES
USA
Here's a stock switch.
1. Switch
2. Spacer
3. bezel
4. key cylinder/key
Jim
SHX669
With the stock switch I've occasionally had to file part of the "notch/shoulder" of the bezel to get it to seat.
Even with two relatively strong men pushing from both sides - LOL -That spring is pretty stout
