Centering front axle
mp
Austin, TX
Trying to figure out how to get my axle centered. Reference points on the axle are easy--centered between innermost radius arm cap bolts. How do I find the center of the frame/body? Would love to use center between inner frame rails, but is the frame centered under the body or offset?
NicksTrix
drop a set of plumb bobs off the sides of both frame rails, use a framing square(s) to the housing knuckle ends. measure the offset and adjust accordingly. I use a ratchet strap to help pull the housing over as well.
hth
hankjr
Is it too simple to pull diagonals from same point on each side to say outer lower caps bolt?
Hank
mp
mp
Austin, TX
don't worry about centering the frame...center the body. Run a stick up the tire and compare to each side wheel flare.
My front end is caged, and has got in a couple fights with some trees and rocks--Can't use it as a reference. I am not trying to center the frame, only find the end point of reference centering the axle off a known point on it.
Steve83
The only absolute reference on the axle for centering it under the chassis is WMS. And if you have the same rim/tire on each side, then the sidewalls are equivalent to using the WMS.
To center the body, measure from the frame to congruent points under the floor:
pbets756
So lets say your frame is not centered over the front axle, hangs over to one side 3/4 more on one side than the other. this is what im going through right now. I have installed new stock 2 degree c bushings and radius arm bushings and they set perfectly even from the level ground. I also installed new track arm bushing and have it all bolted together and the frame hangs closer to the passenger side than the drivers side. there is no adjustment in the track arm so I don't know how this can be pulled over. Paul
mortimersnerd
An adjustable track bar is proper solution unless youve got the tools to custom build one.
pbets756
I think I have it figured out. It was perfect before when it was all together with engine and body mounted. I took body, engine and tranny out for restoration to install new poly bushings so there is no weight on the frame presently. when I apply weight down on the frame it wants to move over to where it belongs. Does this make sense. If so should I loosen track arm bolts and wait to tighten until after the engine, trans and body are installed.
mortimersnerd
That makes sense. Don't bother loosening the bolts. A mile of driving will settle it out just fine. You don't want to risk forgetting to tighten them again.
pbets756
thanks for the help guys. Yeah its all going back to stock and when I got everything bolted together I noticed I had excessive tow in. Then after putting some weight down on the frame the tow in went back out and the frame evened out. Im sure all will be perfect when the engine, tranny and body are back in. I will get it aligned for sure. thanks Paul
