Changed intake now won’t start
gr8scott
As sure as I can be. I even used one of those TDC indicators that the piston pushes up.
The thing is, there's 2 TDC's. Compression stroke, and exhaust stroke. Maybe you accidently set it up on the exhaust stroke and now it's timed "180 out". Here's how I find TDC on the compression stroke:
Remove plug #1, put my thumb over the hole, and using a remote starter start bumping the engine until I feel pressure against my thumb. At that point it's close, so I take a big ratchet and rotate the motor manually to 0° TDC.
B
Brewbro21
Ive done that, and after using that TDC indicator, I’m positive my timing marks are accurate as well. I was hoping I was 180 out…that’s an easy fix.
