Slumlord
Hey gang,
After I read this post about how the owner didn't know what this "line conected to a valve" was. Apparently, it was/is vent lines that run from your gas tanks to a charcoal canister mounted to the firewall. Today, I checked and found that I did not have the lines running under my Bronco just below the passengers door, on the outside of the frame. It looks as though I have the holes drilled for it, yet, no lines. This means, I do not have anything hooked up to the charcoal canister, if I even have it (I didn't look after I saw I didn't even have the lines).
This raises two questions for me:
1) Could this be a reason why my truck smells so heavily like gas when I drive her?
2) I have to go for emissions testing this coming week. The PO got his emissions taken care of then he had a custom exhaust put on the truck. This is probably why the lines were removed in the first place, is my guess. So, with that being said, and not knowing exactly what Colorado allows as "legal" or not, should I be concearned going into my tests?
Thanks gang!!
Thanks gang!!
