I plan on getting a set of wildhorses Extream Axles;
There is two kinds, Ford Brakes and chevy Brakes,
I emailed wildhorses about the difference and this is what he said:
"You can use either axle set with the Chevy disc brake conversion, at least the one we carry. If you have the axles for the Ford brakes and you install the Chevy conversion you will not be able to use the C clipt hat would normally go on the outside of the axle, in stock form. This is not really an issue though. Most people just go without and have no problems. If you are going to install new axles along with the Chevy disc brake kit then you might consider going with the Chevy axles. There is no difference in price. The difference between the two axles is on the outer axle. The Chevy axle is 1/2 inch longer than the Ford. Whether Ford or Chevy, well, we do sell the Chevy conversion so my choice there is a bit biased, but the reality is that there is less involved in the conversion and the parts are much more
common. The Ford setup would also necessitate swapping out your knuckles. This would then also mean possibly needing to change your tie rod as well. It is basically more work and added expense."
So after hearing this i think i am gonna get the che*y brake axles and do the che*y discs........
Nick~
