Cheap LED Interior Lighting
ryan287
Orange County, CA
This project could be considered cheesy, but it started out as a practical solution to interior lighting, minimizing power draw, wire connections, and switches - and for cheap! (kid approved as well)
---> LED lights, controller, connectors = $30
---> extra wire = $.30/ft (10ft)
---> Ethernet jack = $2.50
---> heat shrink tubing, solder...
- - -> ethernet cable - free! We all have extras laying around
The remote works well, and the lights are very bright.
I found this guy locally on Craig's List - he is very inexpensive from what I've seen and actually has a store front (Red Tag Lighting, Santa Ana CA).
http://www.amazon.com/Waterproof-St...8H3S/ref=aag_m_pw_dp?ie=UTF8&m=A13ZQM9C7X9ID6
Only problem I'm running into is having the strips stick upside down to the LineX in my bed rails in the back. I'm hesitant to use clear silicon because I think that stuff always makes a mess and takes forever to get sticky. Any recommendations will be appreciated.
TAC
Pocatello, ID
That's cool. If you don't have rear interior quarter panel inserts they would also look cool recessed in the upper interior section of the rear quarter panels.
ryan287
ryan287
Orange County, CA
Thanks man,
Yeah, that's where I've been trying to stick them, but the sticky backing the lights come with isn't enough to stick to my LineX - they keep falling down. Wondering if anybody can recommend a clear, quick setting glue that will work. I don't want to make a mess and be stuck trying to hold them in place while the stuff dries.
Thanks,
bronc50
Did the same thing!
With same stick problem......
What I did was since I used the waterproof leds they have a silicone cover so I simply laid a small bead of silicone beside the edge of the led strip and mating surface a quick swipe with the finger and let dry. I love the lights
Also have full undercarriage and halo headlights
ryan287
ryan287
Orange County, CA
Did the same thing!
What I did was since I used the waterproof leds they have a silicone cover so I simply laid a small bead of silicone on the beside the edge of the led strip to the mating surface a quick swipe with the finger and let dry.
I'll probably end up using silicon also, but I hate that stuff - gets everywhere when I use it, like a kid with syrup (haha).
TAC
Pocatello, ID
Sorry, should have read your comments closer rather than just looking at the pictures. I used a high strength pressure sensitive adhesive tape (I think acrylic adhesive) to stick my speaker wires to the bed liner under the tub. I will try to find the exact brand. They have held up so far.
ryan287
ryan287
Orange County, CA
Why not try some 3m heavy strength velcro?
Brett
I was worried about the velcro coming off too, but when I was in the aisle at the hardware store I saw some double stick carpet tape that was reinforced with fibers - a step below foam tape thickness. I was hoping to find some of that 3M autobody panel double sided tape.
ryan287
ryan287
Orange County, CA
Did the same thing! With same stick problem......What I did was since I useswitch he waterproof leds they have a silicone cover so I simply laid a small bead of silicone beside the edge of the led strip and mating surface a quick swipe with the finger and let dry. I love the lights. Also have full undercarriage and halo headlights
Your pictures just downloaded - that looks very cool. How many controllers are you running? Do you have any that are hard wired (not using the remote, but a switch)?
bronc50
All LEDs use one controller but are all independently controlled with switches. 1 main switch that controllers the controller and interior LEDs and two other for the undercarriage and head lights I can choose to drive and run the interior and halos or the interior and undercarriage or all 3. I also have door pins the will also activate the interior LEDs with the main switch off
Pokey71
FWIW.
I used some cheap made in china LED's under my bronco. I use RightStuff silicone on the bottom and "glued" earth magnets to the LED's.
Its been over a year and they have not fallen off.
panteramatt
Been wanting to do this for interior light. If I bought the kit, I would run them like your one under dash and one on each side of the rear tub. Can you just solder regular wires from the break between the dash and rear?
ryan287
ryan287
Orange County, CA
Magnets are a great idea! Gives me option of having a light source/flashlight if needed. With a little extra power cable they would make a great exterior camping lights.
Thanks!
ryan287
ryan287
Orange County, CA
Yup, I think the wire I used was 22ga. If you are going to run RGB (Red, blue, green) LED's, then you need 4 wires to connect the strips. The wire I used has (4) 22ga wires in it (@ $. 30/ft), so that made it a lot cleaner than running individual wires.
The whole reason for the Ethernet jack and Cat 5 connector was to minimize the rats nest of wires when I brought the two rear strips (8 wires) into the dash strip (4 wires). Its also easy to disconnect.
Pokey71
Thanks!
I cut all my wires the same length with weather proof connectors. if one goes out, i can simply plug an extra one in its place.
They are great to use as service lights. just grab one off of the frame, plug in an extension cord i made and WAH LAH!
I bought the magnets off of ebay for $5 for 20.
Sniper
Omaha Nebraska
would love to run some under the bronco aswell as interior under the dash and in the lips above the wheel well so when i remove the top i can still have some light but not need to mess with unplugging the cables, haven't really messed with LED's or electrical alot. and not sure where i am going to hook it to for power, probably instrument panel lights, i have a huge birdsnest of wires under the dash from the PO and i'm lost on it lol. need to try and clean it up.
ordered the kit you linked
bronc50 who did you get the halo headlights from? do they still have hi/low or when do the halo's come on? haven't had any halo's on my trucks, so no real experience with them, but my stock lights are from 69 and definitely don't illuminate as much as i would like them to.
bronc50
The halo headlights are a H4 conversion light and still have hi/low
The halos are wired seperatly and can be used with out the head lights on.
They are from redline lumtronix
http://haloheadlights.co/
Ask for tony tell him josh with the eb in Canada let ya know about them
