Pechin0351
- Jun 30, 2010
- 82
I looked around and saw some of y’all talking about this in the past, but didn’t really see a resolution. So here we go:
Wild Horses EFI Harness, 5.0, A9M ECU, AAW wiring harnesses, Dakota Digital HDX gauge.
Okay so I have been hooking stuff up, truck runs great, isles great, all that. The CEL is direct wired from the EFI harness to the DD gauge control box. My CEL is always on, and I can’t get it to flash for a test mode. I do not have a secondary light hooked up.
Does this require a larger load? Maybe a pull-up resistor to 12V, or a incandescent light? I did try hooking up an LED with a resistor with it to 12V but that’s a tiny load. What did I miss, how did you guys running a Digital gauge with CEL do it?
UPDATE:
I found that my issue was a burned trace inside the ECU. Checking resistance between the test connector wire (Pin 46) and the ground side of the battery terminal should result in a very low resistance. Mine was sitting around 2.2K OHMS. Since Pin 46 just connects to the ground through the ECU, I tore it open and found the burned trace, pictures are below. Soldering a wire to fix the broken trace solved my problem.
UPDATE:
