I am going to pull it all apart and clean it up good and inspect everything. I am also going to twins stick it so I am going to make the internal mods while I have it apart.
I played with it the other day and everthing turns smooth and there are no visible leaks. I am hoping I the berrings look as good as they feel when I take it all apart. I may replace them while I have it apart just for piece of mind. What do you guys think?
All you need to do is inspect them and replace them if they are bad. It is doubtful you will find any problems though. I didn't even pull all of the bearings off mine. I left the center gear set in and only pulled the covers off for the upper/lower gears and pulled those out. Everything looked good so I didn't go any further. Do be careful not to lose any of the needle bearings when you pull the gears out. Use white grease when putting them back in so they will stick to the race until the shafts are put back together.
