I'm in the process of getting my gas tank repaired (leak) and also rebuilding my carburetor. As a result, my fuel line is disconnected on both ends. I have had trouble with varnish and crud in my carburetor due to old/bad gas in the past. Consequently, I'm wanting to also clean out my fuel line at the same time. I have an electric fuel pump installed in the line, and I thought about running some carb cleaner up through the line a few times. Is this ok to pump carb cleaner through the fuel pump? Is there a better way to clean it?
Thanks!
Thanks!
