Cleaning latches
nboost
Edmond, OK
What is the best way to clean my door/ tailgate latches? They have built up over the years with grease and dirt and need a good cleaning. Is there something I can soak them and then re-lube them.
miikee73
Shadetree Guru
Aloha
Something like Simple Green and a nylon parts brush should cut the grime.
Then lube it with a non-sticky lube like motorcycle chain lube or silicone spray.
WD 40 is not a good lube,it has a 1000 uses ,but long lasting lube isn't one of them.
I take it you want to do this without removing them from the Bronco.
patterdale
If you are leaving them in the Bronco shoot them with Brake cleaner and follow up with a blast of air. Then use a graphite or silicone lock lube.
broncnaz
I used oven cleaner on my door latches took off all that old hardened grease then just lubed them up again worked great.
ugly74
Bronco abuser
Yup, oven cleaner works great. If i dont feel like taking them out, ill use brake clean and compressed air. Ive had pretty good success using a dry teflon lube on them too. Doesnt attract a bunch of dirt
