both are really rusty, and nasty, i was thinking of having them sent out to be dipped in an acid bath and then galvanized? has anyone done this before? or have any other ideas for fixing these up?
You could use a product like OSPHO. It converts the rust to a protective coating. Works great on fence posts. I'm afraid too much labor cost would put the cost over new ones.
I had mine cad. plated,zinc is also a way to go. When they plate it they run it though a pickling solution first that strips everything including lite rust.
When they do the plating it comes out silver or you can opp for the gold does a good job.
The biggest problem is you not even close to the minimun charge.
i was thinking of cad plating too. i was hoping if i call some of the vendors we use at work, they might do me a favor since we do a lot of business with them, and they could run my stuff through. we will see what they say.
im not having much luck on the phone this morning....
if i got these stripped at a radiator shop, is there anything i could spray on myself that might hold up? besides POR gas tank sealer... kinda expensive for the amount i would need
soooo i dunno what to do. shot down by two local places today, neither had hot tanks... one guy didnt think that would be the best way. he suggested sand blasting and muratic acid...
