pgilchri
I am planning on painting my Bell housing, NV3550, and D20 with silver Por-15. But first I need to clean and degrease +30 years of crud off of the bell housing and t-case. My question is can I safely use a pressure washer on the bell housing to get the crud off? or will it rust up on me. I know por-15 likes rust but I would just assume avoid it if possible. I was planning to use simple green as the degreaser and then marine clean/metal ready to finish the prep. I am not sure what to do with the t-case as it is separated from the trans and thus is exposed and I know I don’t want water inside the case.
I would also like to clean up my GT-40 lower intake while I have it removed. I know its aluminum and should be fine with the pressure washer but there is some kind of steel plate on the backside, so is this a good idea? Any advice is appreciated.
-Patrick
-Patrick
