And shifters... With the stock type shifter it's going to clock with the transfer case and come through the floor in a very strange way.
A custom setup can be fabbed up probably, and maybe a twin stick is set up to be more easily modified than the stock one.
But it's a big thing to consider.
Are you actually going to four-wheel your Bronco? Serious trails and hard rock stuff? If not, then I say don't even bother with the clocking. If a little concerned anyway, just make a nicer skid plate.
I'm not against gaining more ground clearance. Just that unless you really need to, it's potentially a lot of work.
