CLUTCH WOES?>>
JokerOfDeception
Whittier friggin cal
dunno about this one, three speed on the floor, 4.11 gears and 35'' tires. when i let out first gear i have to do it preeeeeeeetty dang slow or else it starts hopping like a horny toad and almost chokes out and dies. clutch going or what? sometimes i can drop it in fine and not have it bog down too much. doesnt need to be tuned or anything either... watcha think boys. ::)
G
Guest
Guest
look it up
Do a search. This issue has been addressed adnauseam.
wildbill
Old Bronco Guy
8) 8) 8) Cluck chatter one thing that worked back in the old days was nose to a tree and slid the cluch a little and that would take it out for a wile other wise new cluch and plate and do the flywheel also good luck. 8) 8) 8) Bill 8) ::) :p
chuck
Ingram, Texas
You should check the drive shaft and trans mounts but it sounds like the clutch. Do not use a rebuilt clutch/pressure plate. Do use a trans jack and do not let the weight of the trans hang on the clutch as you are installing it.
civilgee
Northport, Alabama
Thanks for the replies...i thought the clutch was shot. I guess I will have to nudge a tree and make this last a little longer. Thanks again.
Chief Master Sergeant
Retired U.S. Air Force
I have the same problem and put it out to the group a few weeks ago. I got the same response, that it was the clutch being contaminated. My situation is weird. If I take the top off, the chatter is almost non-existent. I was told it is the clutch, but have been too cheap to get it fixed as of yet.
Wildturkey
BANNED
Coker, Alabama
[quote author=civilgee link=board=5;threadid=18446;start=0#msg141362 date=1055283723]
[/quote]Hey man..I sent you an email about some help on that clutch problem.
hackyrat
Know that jumpy ride well. After three clutches, linkage bushings, motor mounts, flywheel work, U-joints, new suspension (which I wanted anyway), rear seals, slippin the clutch, and lots of sweat I went with an auto 4R70W and have been smiling ever since. The clutch that worked the best for me was a LUK but it too started chattering like mad after awhile. I do believe Chuck has something there about not using rebuilt stuff. The auto cost me lots of money and there were some set backs but I love it now.
Funny side note....I don't have this problem going into reverse. It's as smooth as can be. Just seems weird that it only does it from start in first gear. I can even take off in 2nd gear and doesn't do it. Doesn't make sense.
ballistic64
Piedmont , SD
When you go to put that new clutch set in,two things should absolutely be done to save yourself future headaches. #1- If your rear main seal leaks,fix it.
#2 - Always have your flywheel milled when installing a new clutch,even if it doesn't seem worn.
chuck
Ingram, Texas
It doesn't take much to warp a clutch disc. Either on install or overheating. Sometimes if you slip the clutch it will warp so sometimes if you get it hot it will warp back straight. It can't hurt to try but I have not had much luck with that. When you install a new clutch be very careful to not let the trans hang on the clutch bacause the disc is easy to warp, you may not notice it for a few weeks but the first time you slip it a little and get it a little hot it will warp.
