Cortez
- Joined
- Jan 29, 2009
- Messages
- 1,205
I'm installing the h-boost brakes this weekend and have it all installed, but having a helluva time bleeding them. I can pump them up to moderate stiffness but can't seem to get them to pump up to a solid stiff pedal feel. I've tracked down a couple leaks and resolved them but still can't seem to get it.
- is a leak the only reason it won't get a firm pedal feel or does that mean I still have air in the lines. I've pumped through about 3 cups of brake fluid.
- I jacked the front off the ground and pumping the pedal doesn't engage my pads to stop a spinning wheel. Is this just because I don't have them bled out good?
- What else should I be looking for??
Any help would be appreciated - thanks!
