Code 67- EEC-IV Catch Codes-???-
KST1
Hi guys,
Well, I've finally got the wiring harness to the point where I can pull KOEO codes. I got codes 67 and some misc. emmissions stuff. Code 67 won't let me pull the KOER codes so I need to figure that out.
I'm trying to find out if my computer is a Manual or an Auto so I can provide the correct input signal to cancel code 67.
I'm running a '88 5.8 so most of the stuff on the web is not telling me what I need (it's all 5.0 stuff). I've checked Fordfuelinjection.com, and while he has a lot of helpful stuff, it's not what I need. Can't find anything on Ford Truck Enthusiasts either.
My EEC-IV catch code (label on the computer) reads 8QJ. I can't find a reference to this anywhere to tell me Manual or Auto.
You guys know if any other tech. resources for the 5.8 catch codes?
Thanks in advance for any and all help.
-D
TrailDawg
Lima, OH
Might try calling a Ford dealer and see if the parts dept. can help you. If that doesn't work, try posting your question over at Ford-Trucks.com in the Computer Tuning section. Webmaster should be able to get you an answer there.
Lttrbox
IF
Not to change the subject, but I would like to know how you set up your MIL (or lack of). Wire from computer into harness with 12V crank and run source?
lars
Been here awhile
NorCal flatlands
I would say your best bet would be to contact Ford Racing at (586) 468-1356. If anyone knows, they will.
