MartyG
- Jun 2, 2010
- 1,124
I cant figure out the issue. When I crank it, it's VERY slow, almost like battery is low...then it kicks over. When it's hot, it's worse. Battery is fine.
It's running very rough...some backfires. Rebuilt the carb (4bbl Holley) and thought it's dialed in.
I checked it with a timing light and it's dead on. Pulled all the spark wires to see if a cylinder is missing and all are good.
I have an MSD unit and I'm seeing arcing from the (MSD) coil from the pos. terminal to the center post.
Coil has no cracks in it. Swapped out a new coil wire...same issue.
There's no vacuum from my vacuum advance but that can't be all of it. Checked for other vacuum probs and can't find any.
What...is...the DEAL?! Any ideas from you enlightened gents are much appreciated.
