Coilovers with hydroboost
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
I’m in the process of trying to mount my 14” Radflo coilovers, and I’m having a tough time getting everything to play nice. I’ve already moved my hb unit and brake pedal over to where the clutch would normally be, but it’s still in the way of the coilover hoop. How have you guys mounted your c/o’s with hb? Oh, and I have a 351W with EFI and a GT40 tubular intake, so moving it over to the normal brake hole isn’t gonna cut it.
rcmbronc
Tomah WI
Room is always tight on this. Here are my pics with several different engines.
rocknhorse76
rocknhorse76
Central WA
Thank you for the pics. I may have to do some more research into moving the hb to where yours is.
JB Fab
Same problem here, moved it clear out of the way......
rocknhorse76
rocknhorse76
Central WA
Jon, that’s a clean setup! Any pics of how you made the brake pedal work under the dash?
