Column mount Tach w/ GPS Speedo?
Schloer2
Anyone found a nice option for a column mount gauge that is predominantly an analog Tach with a secondary gps Speedo (digital or analog)? I have seen options that are dominated by the Speedo with a small tach but not the other way around. Would love for it to have an aesthetic similar to the OEM gauge cluster.
Thanks for any suggestions.
Cheers
4xfun
That is going to be a difficult find. For that combination, the speedometer should be the dominant gauge. Have you looked at the vender's options? There are some digital options that may give you what you want. If your speedometer works, I would suggest just using a column mounted tach.
Schloer2
Schloer2
Agree - I have accepted that I won’t find what I want in a combo gauge so I’m going to order the Toms OE Style tach assuming I can confirm it will work with the Pro Flo 4 signal
Madgyver
Bronco Madman
i did the amazon gps thing since my speedo gear is way off. I'd post a pic but lost my privilege.
