- Dec 5, 2021
- 56
I'm am in the process of a frame up build of a '73 U15.
I have sourced an AOD from an '89 Bronco to replace my stock C4. I'm going to drop it off at a transmission shop but I'm very new to this and I don't know what instructions they will need. I will give them the AOD adapter tail housing and I plan to use an Ididit tilt column so I will provide them with the appropriate linkage. Anything esle I should provide them?
What else will I need to tell them? What questions should I be ready to answer?
Should I use the stock torque converter? anything else specific?
some details about my plan:
302 stroked to 347
d20 transfer case
9 inch rear and d44 front with 4.11(open to suggestions?) gears - will be exclusively street driven.
either 31 or 33 inch tires
2.5" suspension lift
1" body lift
Thanks very much for the guidance.
302 stroked to 347
d20 transfer case
1" body lift
